Aller au contenu principal
Ninja NJ600 Circuit Board Replacement
Ce dont vous avez besoin
  1. Ninja NJ600 Circuit Board Replacement, Blender Base Cover: étape 1, image 1 de 2 Ninja NJ600 Circuit Board Replacement, Blender Base Cover: étape 1, image 2 de 2
    • Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
  2. Ninja NJ600 Circuit Board Replacement: étape 2, image 1 de 2 Ninja NJ600 Circuit Board Replacement: étape 2, image 2 de 2
    • Without removing any screws, you can pull the 2nd layer free from the base. Do this now and set it down gently next to the base.
    • The power cord runs through a hole in the side of this layer. Squeeze the cord and pull it through the hole to separate the layer from the cord.
  3. Ninja NJ600 Circuit Board Replacement: étape 3, image 1 de 3 Ninja NJ600 Circuit Board Replacement: étape 3, image 2 de 3 Ninja NJ600 Circuit Board Replacement: étape 3, image 3 de 3
    • Using the Phillips #2 screwdriver, remove these six screws (13mm long, 6mm head diameter). Then carefully remove this layer, and rest it next to the blender base.
    • Be careful not to damage the two wires that are keeping this third layer attached to the base.
  4. Ninja NJ600 Circuit Board Replacement, Circuit Board: étape 4, image 1 de 1
    • Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
    • Be careful not to scratch the circuit board with the screwdriver.
  5. Ninja NJ600 Circuit Board Replacement: étape 5, image 1 de 1
    • Using a pair of scissors or wire cutters, cut the zip tie holding these wires.
    • This will give the circuit board more range of motion.
  6. Ninja NJ600 Circuit Board Replacement: étape 6, image 1 de 3 Ninja NJ600 Circuit Board Replacement: étape 6, image 2 de 3 Ninja NJ600 Circuit Board Replacement: étape 6, image 3 de 3
    • Desolder the five wires from the solder pads shown.
    • If you do not know how to do this, iFixit has a guide describing the process.
    • Before you begin to desolder these wires, flip the board over to confirm that you are about to desolder the correct component.
    • Soldering iron is very hot, use caution when handling
  7. Ninja NJ600 Circuit Board Replacement: étape 7, image 1 de 1
    • After the wires have cooled enough to touch, carefully slide the circuit board free of the wires.
    • NOTE: keep track of which pad each wire was soldered to. This is important for your blender to function.
To reassemble your device, follow these instructions in reverse order, but solder the wires back to the board.
2 autres ont terminé cette réparation.
Kody D
Membre depuis le 04/01/15
537 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 24-2, Lancaster Spring 2015 Membre de l'équipe Cal Poly, Team 24-2, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G2
4 membres
6 tutoriels rédigés
4 commentaires
Good article. How do I get hold of a board?
Odman - Réponse
Where can I buy de circuito board?
carlareis1 - Réponse
Where can i buy the circuit board ?
Adesoye Olatunji - Réponse
Hi, where can I buy this board please?
Daniel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 30
Total : 3,427
