Aller au contenu principal
Nintendo 3DS Battery Replacement
Ce dont vous avez besoin
  1. Nintendo 3DS Battery Replacement, Back Cover: étape 1, image 1 de 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: étape 2, image 1 de 2 Nintendo 3DS Battery Replacement: étape 2, image 2 de 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: étape 3, image 1 de 3 Nintendo 3DS Battery Replacement, Battery: étape 3, image 2 de 3 Nintendo 3DS Battery Replacement, Battery: étape 3, image 3 de 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
45 autres ont terminé cette réparation.
David Hodson
Membre depuis le 04/13/10
150 467 Réputation
127 tutoriels rédigés
7 commentaires
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - Réponse
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - Réponse
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - Réponse
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 74
7 derniers jours : 473
30 derniers jours : 2,158
Total : 67,217
