Aller au contenu principal
Nintendo 3DS Charger port Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Nintendo 3DS Charger port Replacement, Charger port: étape 1, image 1 de 1
    • Take out the 4 screws on the back of the system using a Phillips #00 Screwdriver.
  2. Nintendo 3DS Charger port Replacement: étape 2, image 1 de 1
    • Remove the back cover
  3. Nintendo 3DS Charger port Replacement: étape 3, image 1 de 1
    • Before proceeding, make sure you have removed the battery.
  4. Nintendo 3DS Charger port Replacement: étape 4, image 1 de 1
    • You will see small black screws in nine different holes. make sure you use the right screwdriver and remove them. Also remove the one silver screw that holds the game cartridge slot.
  5. Nintendo 3DS Charger port Replacement: étape 5, image 1 de 1
    • After you have unscrewed all of the screws. Carefully remove the back with a spudger.
  6. Nintendo 3DS Charger port Replacement: étape 6, image 1 de 1
    • After you pull it open, you will see the motherboard. Locate the charging port. It should look like this.
  7. Nintendo 3DS Charger port Replacement: étape 7, image 1 de 1
    • Using a soldering iron, desolder the old charging port.
  8. Nintendo 3DS Charger port Replacement: étape 8, image 1 de 1
    • If you got a charger port for a 3DS, you can skip this step. From another 3DS, desolder the charger port.
  9. Nintendo 3DS Charger port Replacement: étape 9, image 1 de 1
    • Solder the new charging port to the motherboard.
4 autres ont terminé cette réparation.
Kaylee Morton
Membre depuis le 11/02/16
275 Réputation
1 tutoriel rédigé
2 commentaires
you solder with everything connected to the mobo??
jrsalinas85 - Réponse
Everything but the battery. I actually took mine out of the case before doing anything. But I kept it connected to the screen. I would not do this without a very fine soldering gun.
Timothy Phillips -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 3,312
