Aller au contenu principal
Nintendo 3DS Motherboard Assembly Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: étape 1, image 1 de 2 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: étape 1, image 2 de 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: étape 2, image 1 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 2, image 2 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 2, image 3 de 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: étape 3, image 1 de 2 Nintendo 3DS Motherboard Assembly Replacement: étape 3, image 2 de 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: étape 4, image 1 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 4, image 2 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 4, image 3 de 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: étape 5, image 1 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 5, image 2 de 3 Nintendo 3DS Motherboard Assembly Replacement: étape 5, image 3 de 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  6. Nintendo 3DS Motherboard Assembly Replacement: étape 6, image 1 de 1
    • Remove the motherboard assembly from the rest of the device.
David Hodson
Membre depuis le 04/13/10
150 455 Réputation
127 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,577
