Aller au contenu principal
Nintendo 3DS NFC Reader Motherboard Replacement
Ce dont vous avez besoin
  1. Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: étape 1, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: étape 1, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Flip the adapter so the bottom side faces up.
    • Remove the cover by pressing the plastic flap and lifting it up with one finger.
  2. Nintendo 3DS NFC Reader Motherboard Replacement: étape 2, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 2, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 2, image 3 de 3
    • Remove the batteries by pressing the positive side towards the negative side and lifting with one finger.
  3. Nintendo 3DS NFC Reader Motherboard Replacement: étape 3, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 3, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 3, image 3 de 3
    • Grab your tri-point screwdriver.
    • Locate the four holes containing the tri-point screws at each corner of the adapter.
    • Using the screwdriver, unscrew all four screws.
    • Put the screws out of the way.
  4. Nintendo 3DS NFC Reader Motherboard Replacement: étape 4, image 1 de 2 Nintendo 3DS NFC Reader Motherboard Replacement: étape 4, image 2 de 2
    • After removing the screws, flip the adapter where the top side faces up.
    • Using your fingers, pull the top off of the adapter.
    • Place the top out of the way.
  5. Nintendo 3DS NFC Reader Motherboard Replacement: étape 5, image 1 de 2 Nintendo 3DS NFC Reader Motherboard Replacement: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using your tweezers, remove the translucent plastic by lifting upwards out of it's peg.
  6. Nintendo 3DS NFC Reader Motherboard Replacement: étape 6, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 6, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 6, image 3 de 3
    • To remove the black slide, use your fingers to slide the black slide out of its slot.
  7. Nintendo 3DS NFC Reader Motherboard Replacement: étape 7, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 7, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 7, image 3 de 3
    • Using the tweezers, carefully lift up the plastic button out of its slot.
  8. Nintendo 3DS NFC Reader Motherboard Replacement: étape 8, image 1 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 8, image 2 de 3 Nintendo 3DS NFC Reader Motherboard Replacement: étape 8, image 3 de 3
    • Using your tweezers, carefully loosen the copper wire from its plastic holder.
    • Then with the tweezers, remove the plastic holding the motherboard in place.
  9. Nintendo 3DS NFC Reader Motherboard Replacement: étape 9, image 1 de 2 Nintendo 3DS NFC Reader Motherboard Replacement: étape 9, image 2 de 2
    • Using your fingers, carefully lift the board and place it down, out of the way.
Ligne d'arrivée
Sruiz84
Membre depuis le 03/21/23
196 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 87-87, Briggs Spring 2023 Membre de l'équipe CSU Los Angeles, Team 87-87, Briggs Spring 2023
CSULA-BRIGGS-S23S87G87
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 26
Total : 261
