Introduction
Replacing the SD board in your 3DS may help resolve issues you're having loading and saving content.
Ce dont vous avez besoin
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
21 autres ont terminé cette réparation.
7 commentaires
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
