Aller au contenu principal
Introduction
This fix is necessary for the owners of N64 controllers when the joystick becomes too loose over time. If the joystick of a controller is loose, game play becomes difficult. Conditions for this fix include: a flat surface, plenty of light, and a method for keeping track of individual components of the controller. Practice caution when using the knife in this fix.
  1. Nintendo 64 Controller Joystick Repair, Nintendo 64 Controller Joystick Repair: étape 1, image 1 de 1
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
  2. Nintendo 64 Controller Joystick Repair: étape 2, image 1 de 1
    • Detach the two wired connections from the small, white box.
  3. Nintendo 64 Controller Joystick Repair: étape 3, image 1 de 1
    • Remove the screws (4.8 mm Phillips head) from the back of the white joystick box.
    • Remove the back panel of the white joystick box.
    • There are many small plastic components loose in this box, so be careful not to lose these.
  4. Nintendo 64 Controller Joystick Repair: étape 4, image 1 de 1
    • Remove the screw (4.8 mm Philips head) from the back of the joystick box.
    • Remove the joystick box from the controller.
  5. Nintendo 64 Controller Joystick Repair: étape 5, image 1 de 1
    • Use a cleaning cloth to remove residue and dirt from any components.
  6. Nintendo 64 Controller Joystick Repair: étape 6, image 1 de 1
    • Free the small, white bowl from its connections to the controller.
    • Remember the order in which each piece was removed.
  7. Nintendo 64 Controller Joystick Repair: étape 7, image 1 de 1
    • Pinch off a small piece of epoxy and knead it in your hand until a uniform color is reached.
  8. Nintendo 64 Controller Joystick Repair: étape 8, image 1 de 1
    • Press the epoxy into the center of the bowl with your finger and add a drop of water into the bowl.
  9. Nintendo 64 Controller Joystick Repair: étape 9, image 1 de 1
    • Place a marble into the bowl and use a push-twist motion to form the epoxy into the shape of the bowl.
    • Excess epoxy will rise above the bowl.
    What can I substitute for a marble?
    Javier Moe - Réponse
  10. Nintendo 64 Controller Joystick Repair: étape 10, image 1 de 1
    • Cut the edges of the excess epoxy with the exacto knife.
    • Repeat steps 8 and 9 until no excess epoxy is left.
  11. Nintendo 64 Controller Joystick Repair: étape 11, image 1 de 1
    • Let the epoxy sit and dry for 30 minutes or until the epoxy is hardened.
  12. Nintendo 64 Controller Joystick Repair: étape 12, image 1 de 1
    • Add a small coat of grease on top of the epoxy with your applicator.
  13. Nintendo 64 Controller Joystick Repair: étape 13, image 1 de 1
    • Apply grease to the bottom of the joystick (the area circled in red)
  14. Nintendo 64 Controller Joystick Repair: étape 14, image 1 de 1
    • Reverse these steps to reassemble the controller.
    • You may want to test the joystick stiffness before reassembling the controller.
The fix is now complete. Move the joystick to test the stiffness. If the joystick is still very loose, you may need to add more epoxy. If the joystick is too stiff, you may need to remove excess epoxy.
10 autres ont terminé cette réparation.
Brittany Slindee
Membre depuis le 23/09/2015
300 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 7-3, Mcmichael Fall 2015 Membre de l'équipe Colorado Springs, Team 7-3, Mcmichael Fall 2015
UCCS-MCMICHAEL-F15S7G3
2 membres
2 tutoriels rédigés
4 commentaires
N64 Joystick Permanent Fix & Refurbish New Parts Cheap
https://youtu.be/IPXgVSyL_rI?t=24
John - Réponse
Sadly, it is out of stock too frequently. I’d prefer fixing rather than replacing.
Javier Moe -
What is the epoxy substance called exactly? I tried searching online but results all come back for JB-Weld coldweld bonding products.
chrisdeliz - Réponse
Yo supuse que se debía reparar las dos piezas del movimiento, pero tambien voy a rellenar ese fondo que indican, gracias
Beto Vera - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 118
30 derniers jours : 587
Total : 31,557
