Aller au contenu principal
Nintendo DSi XL Upper Case Replacement
Ce dont vous avez besoin
  1. Nintendo DSi XL Upper Case Replacement, Battery: étape 1, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Battery: étape 1, image 2 de 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Upper Case Replacement: étape 2, image 1 de 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Upper Case Replacement, Lower Case: étape 3, image 1 de 3 Nintendo DSi XL Upper Case Replacement, Lower Case: étape 3, image 2 de 3 Nintendo DSi XL Upper Case Replacement, Lower Case: étape 3, image 3 de 3
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Upper Case Replacement: étape 4, image 1 de 1
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Upper Case Replacement: étape 5, image 1 de 3 Nintendo DSi XL Upper Case Replacement: étape 5, image 2 de 3 Nintendo DSi XL Upper Case Replacement: étape 5, image 3 de 3
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Upper Case Replacement: étape 6, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 6, image 2 de 2
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Upper Case Replacement: étape 7, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 7, image 2 de 2
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
  8. Nintendo DSi XL Upper Case Replacement, Motherboard: étape 8, image 1 de 1
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
  9. Nintendo DSi XL Upper Case Replacement: étape 9, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 9, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
  10. Nintendo DSi XL Upper Case Replacement: étape 10, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 10, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
  11. Nintendo DSi XL Upper Case Replacement: étape 11, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 11, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
  12. Nintendo DSi XL Upper Case Replacement: étape 12, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 12, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
  13. Nintendo DSi XL Upper Case Replacement: étape 13, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 13, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
  14. Nintendo DSi XL Upper Case Replacement: étape 14, image 1 de 1
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
  15. Nintendo DSi XL Upper Case Replacement: étape 15, image 1 de 1
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
  16. Nintendo DSi XL Upper Case Replacement: étape 16, image 1 de 1
    • Deroute the microphone and antenna cables through the slot in the motherboard.
  17. Nintendo DSi XL Upper Case Replacement: étape 17, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 17, image 2 de 2
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
  18. Nintendo DSi XL Upper Case Replacement: étape 18, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 18, image 2 de 2
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
  19. Nintendo DSi XL Upper Case Replacement, Lower Display Assembly: étape 19, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Lower Display Assembly: étape 19, image 2 de 2
    • With the console still upside-down, open the DSi XL slightly.
    • Push the lower display away from the upper case.
    • Remove the lower display from the DSi XL.
  20. Nintendo DSi XL Upper Case Replacement, Rear Bezel: étape 20, image 1 de 3 Nintendo DSi XL Upper Case Replacement, Rear Bezel: étape 20, image 2 de 3 Nintendo DSi XL Upper Case Replacement, Rear Bezel: étape 20, image 3 de 3
    • Turn the DSi XL over and open the display.
    • When re-assembling the device, be sure to re-install the ABXY and Start/Select buttons, as they are likely to fall out once the handheld console is turned over.
    • Use a pushpin to remove the four plastic screw covers on the front bezel.
  21. Nintendo DSi XL Upper Case Replacement: étape 21, image 1 de 1
    • Remove the four 3.5 mm silver Phillips screws securing the rear bezel to the front bezel.
  22. Nintendo DSi XL Upper Case Replacement: étape 22, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 22, image 2 de 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  23. Nintendo DSi XL Upper Case Replacement: étape 23, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 23, image 2 de 2
    • Insert a spudger into the gap between the front and rear bezel.
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  24. Nintendo DSi XL Upper Case Replacement: étape 24, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 24, image 2 de 2
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  25. Nintendo DSi XL Upper Case Replacement: étape 25, image 1 de 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  26. Nintendo DSi XL Upper Case Replacement: étape 26, image 1 de 1
    • Using the flat end of a spudger, pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  27. Nintendo DSi XL Upper Case Replacement, Microphone: étape 27, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Microphone: étape 27, image 2 de 2
    • Remove the Phillips screw holding the metal securing bracket in place.
    • Lift the metal bracket off the camera.
  28. Nintendo DSi XL Upper Case Replacement: étape 28, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 28, image 2 de 2
    • Use the tip of a spudger to lift the microphone from its seat on the front display bezel.
  29. Nintendo DSi XL Upper Case Replacement: étape 29, image 1 de 1
    • De-route the microphone cable.
  30. Nintendo DSi XL Upper Case Replacement: étape 30, image 1 de 3 Nintendo DSi XL Upper Case Replacement: étape 30, image 2 de 3 Nintendo DSi XL Upper Case Replacement: étape 30, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Pull the microphone cable through the right hinge connecting the front bezel and upper case.
    • Use the pointed end of a spudger to guide the connector at the end of the microphone cable through the hinge.
    • To replace the microphone, use a pair of tweezers to guide the connector through the hinge.
  31. Nintendo DSi XL Upper Case Replacement, Wi-Fi Antenna: étape 31, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Wi-Fi Antenna: étape 31, image 2 de 2
    • Lift the Wi-Fi antenna off the front display bezel.
    • De-route the Wi-Fi antenna cable from its grooves at the bottom of the front display bezel.
  32. Nintendo DSi XL Upper Case Replacement: étape 32, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 32, image 2 de 2
    • Pull the Wi-Fi antenna cable through the right hinge connecting the front bezel and upper case.
  33. Nintendo DSi XL Upper Case Replacement, Upper Display Assembly: étape 33, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Upper Display Assembly: étape 33, image 2 de 2
    • Lift both of the speakers from their seats on the front display bezel.
  34. Nintendo DSi XL Upper Case Replacement: étape 34, image 1 de 1
    • De-route the speaker wires that run above the upper display screen.
  35. Nintendo DSi XL Upper Case Replacement: étape 35, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 35, image 2 de 2
    • Remove the upper display assembly.
  36. Nintendo DSi XL Upper Case Replacement, Upper Case: étape 36, image 1 de 2 Nintendo DSi XL Upper Case Replacement, Upper Case: étape 36, image 2 de 2
    • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
    • Lift the power board off the upper case.
  37. Nintendo DSi XL Upper Case Replacement: étape 37, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 37, image 2 de 2
    • Open the case slightly.
    • Push the directional pad up through the upper case and remove it from the upper case.
    • Push the power button up through the upper case, and remove it from the upper case.
  38. Nintendo DSi XL Upper Case Replacement: étape 38, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 38, image 2 de 2
    • Remove the LED diffuser and black retaining bracket by turning the upper case upside-down and letting both pieces fall into your hand.
  39. Nintendo DSi XL Upper Case Replacement: étape 39, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 39, image 2 de 2
    • The front bezel is held in place by the clutch hinge on the left side of the DSi Xl=L.
    • Using the tip of the spudger, push the clutch hinge to the left.
    • You will hear a "click" when the clutch has been completely displaced. Some force will be required.
  40. Nintendo DSi XL Upper Case Replacement: étape 40, image 1 de 2 Nintendo DSi XL Upper Case Replacement: étape 40, image 2 de 2
    • Lift the front bezel off of the upper case, tilting the left side of the front bezel away from the upper case first.
  41. Nintendo DSi XL Upper Case Replacement: étape 41, image 1 de 1
    • Remove the hollow hinge pin from the right side of the DSi XL.
    • The upper case remains.
3 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
128 242 Réputation
143 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 066 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 75
Total : 13,487
