Aller au contenu principal
Nintendo Entertainment System Controller Cable Replacement
Ce dont vous avez besoin
  1. Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: étape 1, image 1 de 2 Nintendo Entertainment System Controller Cable Replacement, Back Cover Removal: étape 1, image 2 de 2
    • Remove the 6 8mm screws in the back cover using a #1 Philips screwdriver.
  2. Nintendo Entertainment System Controller Cable Replacement, Loosen Cable: étape 2, image 1 de 1
    • Lift the back cover off the controller.
    • Remove the cable from its holders to facilitate PCB removal.
  3. Nintendo Entertainment System Controller Cable Replacement, PCB Removal: étape 3, image 1 de 1
    • Lift the PCB straight up and out of the controller. Turn the board over to access the solder joints for the cable.
    • Desolder the 5 connections and solder in your new cable.
    • Wire colors are printed on the reverse side of the board.
themap504
Membre depuis le 01/08/15
80 Réputation
1 tutoriel rédigé
Un commentaire
My replacement plugs have different colors. Colors are yellow, white, red, black, and green. I’m also doing a max controller not regular nes controller. The max has yellow, red, white, red, and orange color schemes. Any advice. I wired up same colors and guessed for rest. figured black could replace one of the reds, and used green to replace orange, but console just resets over and over with that controller plugged in.
Daniel Melvin - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 49
Total : 1,979
