Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The battery is a rectangular unit with electrical information printed on one side. It is located on the back of the Game Boy Advance SP.
  1. Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
    • Use a standard Phillips #00 screwdriver to loosen the 4mm screw that keeps the battery cover attached to the device.
  2. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Lift the battery cover up and remove it from the device.
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  4. Use your fingers or a plastic opening tool to remove the battery from the device.
    • Use your fingers or a plastic opening tool to remove the battery from the device.
For reassembly, follow the instructions in reverse order.
19 autre(s) ont terminé cette réparation.
Rocco Lattanzio
Membre depuis le 11/01/2013
725 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 17-22, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 membres
19 tutoriels rédigés
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Réponse
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 10
7 derniers jours : 69
30 derniers jours : 266
Total : 23,240
