Aller au contenu principal
Nintendo Game Boy Advance SP Buttons Replacement
Ce dont vous avez besoin
  1. Nintendo Game Boy Advance SP Buttons Replacement, Battery: étape 1, image 1 de 1
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Buttons Replacement: étape 2, image 1 de 1
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Buttons Replacement: étape 3, image 1 de 1
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: étape 4, image 1 de 2 Nintendo Game Boy Advance SP Buttons Replacement, Back Cover: étape 4, image 2 de 2
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Buttons Replacement: étape 5, image 1 de 1
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Buttons Replacement, Motherboard: étape 6, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Buttons Replacement: étape 7, image 1 de 1
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
  8. Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: étape 8, image 1 de 3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: étape 8, image 2 de 3 Nintendo Game Boy Advance SP Buttons Replacement, Removing the Trackpads: étape 8, image 3 de 3
    • Using your fingers, gently lift and remove the trackpads covering the following:
    • 'A' and 'B' buttons
    • Directional Control Button Pad
    • 'Start' and 'Select' buttons
  9. Nintendo Game Boy Advance SP Buttons Replacement, Buttons: étape 9, image 1 de 3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: étape 9, image 2 de 3 Nintendo Game Boy Advance SP Buttons Replacement, Buttons: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • Using tweezers or fingers, lift and remove:
    • Directional control button pad
    • 'Start' and 'select' buttons
12 autres ont terminé cette réparation.
Jose Bautista
Membre depuis le 01/11/13
685 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-22, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 membres
41 tutoriels rédigés
5 commentaires
Hi,
How do I fix my SP Brighter when A and B buttons are simultaneously pressed, the system turns off? Please Help! Thank you in advance!
Jikan - Réponse
there is most likely a crack in the mother board or the battery has too much pressure placed onto it
you can fix this by changing the position of the battery and putting something to stop it from moving around so it fits tightly
Taahaco 2005 - Réponse
HI there! My problem is that I have to press the button A harder for the action to be registered, how can I fix that?
アラン - Réponse
The L and R buttons done work, they go in perfectly fine but would it be the 2 buttons under them that aren't working? If so then how would I remove and replace them safely
Topi2756 - Réponse
The buttons L and R don't work, they go in fine so I'm thinking that it's the buttons on the inside that are damaged. If that is the case then how would I remove and replace them safely?
Topi2756 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 61
30 derniers jours : 202
Total : 24,314
