Introduction
La carte de circuit imprimé connecte tous les composants dans le contrôleur et fournit un support structurel pour les boutons, les bâtons et les copeaux.
Ce dont vous avez besoin
Placez le contrôleur (boutons) sur une surface solide.
Retirez les six vis TRI-Wing Y0 de 9,2 mm qui maintiennent le panneau arrière en place.
Soulevez doucement le panneau arrière vers le haut, le séparant du panneau avant.
For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
Saisissez le bouton Z par la cheville avec une pince à épiler et retirez-le du contrôleur.
So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
Décrochez soigneusement le câble qui est bouclé autour de la cheville.
Um can soneone explain the peg and cable part? I dont understand it...
I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
My1 -
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
5 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
Yeah this isn't very in-depth, I was hoping for a little more. I need to desolder and rewire the buttons to use for another project and I was hoping this might be a nice guide to help me do that... it's not.
You left out the fun facts about every part and components so we know what the are and what they do. Well for me that would have been ideal as I'm fixing 2 controls that don't do anything and I already have to fix a game cube as I got 2 and one works and one don't lol
