Introduction
Le bouton Z est situé au-dessus de la gâchette droite mais fonctionne comme un bouton.
Ce dont vous avez besoin
Placez le contrôleur (boutons) sur une surface solide.
Retirez les six vis TRI-Wing Y0 de 9,2 mm qui maintiennent le panneau arrière en place.
Soulevez doucement le panneau arrière vers le haut, le séparant du panneau avant.
For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
Saisissez le bouton Z par la cheville avec une pince à épiler et retirez-le du contrôleur.
So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
7 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
6 commentaires
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
My bad no pic it's a pelican wireless controller
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Does anyone know where to buy the actual button for the Z button? I can’t seem to find one where the pins are further apart up top and closer together towards the bottom of the button. I only see the opposite.
