Aller au contenu principal
Nintendo NES Advantage B Button Replacement
Ce dont vous avez besoin
  1. Nintendo NES Advantage B Button Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage B Button Replacement: étape 2, image 1 de 2 Nintendo NES Advantage B Button Replacement: étape 2, image 2 de 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage B Button Replacement, Circuit Board: étape 3, image 1 de 2 Nintendo NES Advantage B Button Replacement, Circuit Board: étape 3, image 2 de 2
    • Remove the three 14 mm screws from the gray cross with a Phillips #0 screwdriver.
    • Lift the gray component away from the device.
  4. Nintendo NES Advantage B Button Replacement: étape 4, image 1 de 1
    • Lift up the black wire and move it to the side.
  5. Nintendo NES Advantage B Button Replacement: étape 5, image 1 de 3 Nintendo NES Advantage B Button Replacement: étape 5, image 2 de 3 Nintendo NES Advantage B Button Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the two silver knobs on the front of the device.
    • Unscrew the two silver nuts using a flathead screwdriver.
    • Remove each silver nut and silver washer using a pair of tweezers.
  6. Nintendo NES Advantage B Button Replacement: étape 6, image 1 de 2 Nintendo NES Advantage B Button Replacement: étape 6, image 2 de 2
    • Remove the remaining three 8 mm screws on the circuit board with a Phillips #0 screwdriver.
    • Remove the silver bracket from the top of the circuit board.
  7. Nintendo NES Advantage B Button Replacement: étape 7, image 1 de 1
    • Remove the circuit board from the controller.
  8. Nintendo NES Advantage B Button Replacement, B Button: étape 8, image 1 de 1
    • Remove the B button from the case (or the circuit board if it got stuck).
Aksel Andreassen
Membre depuis le 09/06/22
288 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 5
Total : 147
