Aller au contenu principal
Nintendo Super Famicom SHVC-001 Controller Port Board Replacement
Ce dont vous avez besoin
  1. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Upper Case: étape 1, image 1 de 1
    • Remove the six 13.5 mm screws on the lower case with a 4.5 mm Gamebit screwdriver.
  2. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 2, image 1 de 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 2, image 2 de 2
    • Flip the Famicom over and set it down.
    • Lift off the upper case.
  3. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: étape 3, image 1 de 2 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement, Controller Port Board: étape 3, image 2 de 2
    • Carefully disconnect the ribbon cable that is attached to the controller board and the main board.
  4. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 4, image 1 de 1
    • Lift the controller port board directly up and out of the chassis.
    • If your new controller port board does not come with a ribbon cable, you will also need to replace that.
  5. Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 5, image 1 de 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 5, image 2 de 3 Nintendo Super Famicom SHVC-001 Controller Port Board Replacement: étape 5, image 3 de 3
    • The next bullet demonstrates how to replace your ribbon cable.
    • Disconnect and remove the old cable and replace it with a new 1.25 mm ribbon cable.
Carter Eason
Membre depuis le 02/05/24
454 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 38
Total : 83
