Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nintendo Switch Joy-con Control Stick Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Nintendo Switch Joy-con Control Stick Replacement, Unscrewing the Joy-con: étape 1, image 1 de 2 Nintendo Switch Joy-con Control Stick Replacement, Unscrewing the Joy-con: étape 1, image 2 de 2
    • Remember to turn off your console before you start repairing to avoid accidental connections with it.
    • First, start by removing these 4 Y00 screws on the back of the joy con.
  2. Nintendo Switch Joy-con Control Stick Replacement, Opening the cover: étape 2, image 1 de 2 Nintendo Switch Joy-con Control Stick Replacement, Opening the cover: étape 2, image 2 de 2
    • Insert the flat side of a spudger on the curved side to pry the back cover open
    • Be very careful though, because there are two ribbon cables for the charging port and the SL/SR buttons!
  3. Nintendo Switch Joy-con Control Stick Replacement, Disconnecting the battery: étape 3, image 1 de 2 Nintendo Switch Joy-con Control Stick Replacement, Disconnecting the battery: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • To avoid damaging components, remove the battery from the controller.
    • Please note that the connector is pulled out vertically and not sideways as a zif connector does.
    • Pull the battery connector with your tweezers from the bottom carefully.
    • Remove the battery by inserting the flat side of your spudger.
    • The battery is stuck to its frame with light adhesive.
  4. Nintendo Switch Joy-con Control Stick Replacement, Removing the Bluetooth antenna: étape 4, image 1 de 2 Nintendo Switch Joy-con Control Stick Replacement, Removing the Bluetooth antenna: étape 4, image 2 de 2
    • Pull the golden SMP RF connector that connects the Bt antenna with the main board.
    • remove the square antenna from the side of the battery compartment.
  5. Nintendo Switch Joy-con Control Stick Replacement, Removing the battery compartment.: étape 5, image 1 de 3 Nintendo Switch Joy-con Control Stick Replacement, Removing the battery compartment.: étape 5, image 2 de 3 Nintendo Switch Joy-con Control Stick Replacement, Removing the battery compartment.: étape 5, image 3 de 3
    Magnetic Project Mat
    $19.95
    • remove the ZR button and its springs. Be careful not to break the clips holding it in place.
    • unscrew the four PH000 screws holding the battery compartment and the ZR button board. There is one hidden on the side of the hd rumble module.
    • The screw of the ZR button board is shorter than the others. Keep that in mind if you are sorting the screws using a magnetic project mat or the cover of a Mako driver kit
    • Pick up the battery compartment.
  6. Nintendo Switch Joy-con Control Stick Replacement, Removing the joystick: étape 6, image 1 de 2 Nintendo Switch Joy-con Control Stick Replacement, Removing the joystick: étape 6, image 2 de 2
    • Unscrew the two PH000 screws holding the joystick down.
    • Make sure to NOT disconnect the two side board cables. It may cause fatal damage to the controller.
    • Before you remove the joystick, remove the secured ribbon cable by opening the clip using the tip of a spudger.
    • Note that there is a small gasket below the joystick and that it has to be re-seated in place before inserting the new joystick.
  7. Nintendo Switch Joy-con Control Stick Replacement, Adding the new joystick: étape 7, image 1 de 1
    • to add the new joystick, push it in firmly and make sure it has fully gone through the gasket I mentioned above.
    • Screw it in and put the ribbon cable in its socket. Don't forget to lock the cable in place.
To reassemble your Joy-con, follow these instructions in reverse order.
19 autres ont terminé cette réparation.
Devnol
Membre depuis le 12/01/18
2 924 Réputation
5 tutoriels rédigés
7 commentaires de tutoriel
Just a tip for people doing this repair. DO NOT remove the two ribbon cables between the two parts unless you absolutely have to. I pretty much destroyed my right joycon doing so. One of the cables was so hard to replace for me that I ended up breaking the clip that holds it in. My mistake, I could’ve been more careful but it’s probably best to just not even take them out in the first place. I’ve heard these cables are very finicky to position correctly anyways.
S C - Réponse Partager
Ok, added the bullet to step 6 so that people know. Thanks for pointing it out!
Devnol - Réponse Partager
I did not need to take off the ZR button to fix mine - so for future fixers, try that part without taking off ZR first. :) THANK YOU for creating this tutorial. This fix WAS SO EASY compared to the 3DS XL fixes I did in the past.
sugartoothfaery - Réponse Partager
You have a point. But it’s probably better to remove it because the chances of breaking it are quite high. These are very sensitive cables, but you were lucky. Someone else though might not be.
I do understand that not taking it off can be difficult, but I also know that putting it back on after taking it off is a pain, because you have to adjust it in a way so you don't destroy the button like I did. If you do have to put it back on, I suggest you take a thin ridged object to put over the button while putting the plastic button piece back in.
Josiah M Giles - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 92
Total : 15,186
