Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Follow this guide to replace a faulty right speaker in the Nintendo Switch Lite.
Note: This procedure requires disconnecting the battery for safety. In order to do this, the shield plate must be removed. The shield plate is bonded to the heat sink with thermal paste, which will need to be cleaned off and reapplied before reinstalling the shield plate.
    • Before beginning this repair, make sure that the device is completely turned off.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the back panel.
  1. Use a Phillips screwdriver to remove the following screws securing the back panel: Two 3.6 mm-long screws on the top of the device
    • Use a Phillips screwdriver to remove the following screws securing the back panel:
    • Two 3.6 mm-long screws on the top of the device
    • Two 3.6 mm-long screws on the bottom of the device
  2. Insert an opening tool into the left speaker grille on the bottom of the device. Twist the opening tool to release the clips securing the back panel.
    • Insert an opening tool into the left speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips securing the back panel.
    • Avoid inserting the opening tool further than required to prevent damage to the speaker module.
  3. Slide the opening tool around the bottom-left corner to release the clips on the left side of the device. Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
    • Slide the opening tool around the bottom-left corner to release the clips on the left side of the device.
  4. Insert an opening tool into the right speaker grille on the bottom of the device. Twist the opening tool to release the clips.
    • Insert an opening tool into the right speaker grille on the bottom of the device.
    • Twist the opening tool to release the clips.
  5. Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device. Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
    • Slide and pry the opening tool around the bottom-right corner to release the clips on the right side of the device.
  6. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  7. Continue sliding and prying the opening tool along the gap on the top of the device to release the clips. Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
    • Continue sliding and prying the opening tool along the gap on the top of the device to release the clips.
  8. Lift the bottom edge of the back panel, opening it like a book. Remove the back panel. Remove the back panel.
    • Lift the bottom edge of the back panel, opening it like a book.
    • Remove the back panel.
  9. Use a Phillips screwdriver to remove the following four screws:
    • Use a Phillips screwdriver to remove the following four screws:
    • Three 3.1 mm screws
    • One 4.5 mm screw
  10. Use a spudger or your fingers to lift the shield plate up and out of the device. You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste. Remove the shield plate.
    • Use a spudger or your fingers to lift the shield plate up and out of the device.
    • You may feel a bit of resistance. This is normal, since the shield plate is slightly bonded to the heat sink with thermal paste.
    • Remove the shield plate.
    • Clean off the old thermal paste from the shield plate and heat sink using isopropyl alcohol and a microfiber cloth. Apply new thermal paste to the heat sink before reassembly.
  11. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector. Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
    • Use an opening tool or your fingernail to flip up the small, hinged locking flap on the motherboard interconnect cable's ZIF connector.
  12. Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard. Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
    • Use a pair of tweezers to slide the interconnect cable out of its connector on the motherboard.
  13. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard. Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
    • Use the point of a spudger to pry the battery connector straight up and out of its socket on the motherboard.
  14. Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard. Do not pull from the wires, or else you risk ripping the wires off the connector.
    • Use a pair of tweezers or your fingers to pull the right speaker cable straight up and out of its socket on the motherboard.
    • Do not pull from the wires, or else you risk ripping the wires off the connector.
  15. Use a Phillips screwdriver to remove the following four screws:
    • Three 2.5 mm screws
    • One 4.5 mm screw
  16. Use your fingers to lift and remove the right speaker module cover. Use your fingers to lift and remove the right speaker module cover.
    • Use your fingers to lift and remove the right speaker module cover.
  17. Insert a spudger into the gap at the top of the speaker. Take care to avoid the speaker wires as you insert the spudger into the gap. Pry the speaker up to lift it out of its recess.
    • Insert a spudger into the gap at the top of the speaker.
    • Take care to avoid the speaker wires as you insert the spudger into the gap.
    • Pry the speaker up to lift it out of its recess.
    • The speaker is adhered with light adhesive inside the speaker module, so a bit of force is required.
    • Remove the right speaker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Lite Answers community for help.
Craig Lloyd
Membre depuis le 10/02/2016
11 749 Réputation
63 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
128 membres
12 959 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 12
Total : 10
