Aller au contenu principal
Nintendo Wii Motherboard Cover Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Nintendo Wii Motherboard Cover Replacement, Motherboard Cover: étape 1, image 1 de 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  2. Nintendo Wii Motherboard Cover Replacement: étape 2, image 1 de 2 Nintendo Wii Motherboard Cover Replacement: étape 2, image 2 de 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  3. Nintendo Wii Motherboard Cover Replacement: étape 3, image 1 de 2 Nintendo Wii Motherboard Cover Replacement: étape 3, image 2 de 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  4. Nintendo Wii Motherboard Cover Replacement: étape 4, image 1 de 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  5. Nintendo Wii Motherboard Cover Replacement: étape 5, image 1 de 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  6. Nintendo Wii Motherboard Cover Replacement: étape 6, image 1 de 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  7. Nintendo Wii Motherboard Cover Replacement: étape 7, image 1 de 2 Nintendo Wii Motherboard Cover Replacement: étape 7, image 2 de 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  8. Nintendo Wii Motherboard Cover Replacement: étape 8, image 1 de 3 Nintendo Wii Motherboard Cover Replacement: étape 8, image 2 de 3 Nintendo Wii Motherboard Cover Replacement: étape 8, image 3 de 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  9. Nintendo Wii Motherboard Cover Replacement: étape 9, image 1 de 2 Nintendo Wii Motherboard Cover Replacement: étape 9, image 2 de 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  10. Nintendo Wii Motherboard Cover Replacement: étape 10, image 1 de 3 Nintendo Wii Motherboard Cover Replacement: étape 10, image 2 de 3 Nintendo Wii Motherboard Cover Replacement: étape 10, image 3 de 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  11. Nintendo Wii Motherboard Cover Replacement: étape 11, image 1 de 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  12. Nintendo Wii Motherboard Cover Replacement: étape 12, image 1 de 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 974
