Aller au contenu principal
Nintendo Wii Motherboard Replacement
Ce dont vous avez besoin
  1. Nintendo Wii Motherboard Replacement, Faceplate: étape 1, image 1 de 2 Nintendo Wii Motherboard Replacement, Faceplate: étape 1, image 2 de 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Motherboard Replacement: étape 2, image 1 de 1
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Nintendo Wii Motherboard Replacement: étape 3, image 1 de 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Motherboard Replacement: étape 4, image 1 de 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Motherboard Replacement: étape 5, image 1 de 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Motherboard Replacement: étape 6, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 6, image 2 de 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Motherboard Replacement, Outer Case: étape 7, image 1 de 3 Nintendo Wii Motherboard Replacement, Outer Case: étape 7, image 2 de 3 Nintendo Wii Motherboard Replacement, Outer Case: étape 7, image 3 de 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Motherboard Replacement: étape 8, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 8, image 2 de 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Motherboard Replacement: étape 9, image 1 de 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Motherboard Replacement: étape 10, image 1 de 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Motherboard Replacement: étape 11, image 1 de 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Wing screw
  12. Nintendo Wii Motherboard Replacement: étape 12, image 1 de 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Motherboard Replacement: étape 13, image 1 de 1
    • Remove the two 8.2 mm Tri-Wing screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Motherboard Replacement: étape 14, image 1 de 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Motherboard Replacement, DVD Drive: étape 15, image 1 de 2 Nintendo Wii Motherboard Replacement, DVD Drive: étape 15, image 2 de 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Motherboard Replacement: étape 16, image 1 de 1
    • Remove the 8.2 mm Tri-Wing screw that was hidden beneath the battery door.
  17. Nintendo Wii Motherboard Replacement: étape 17, image 1 de 1
    • Remove the two 8.2 mm Tri-Wing screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Motherboard Replacement: étape 18, image 1 de 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Motherboard Replacement: étape 19, image 1 de 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Motherboard Replacement: étape 20, image 1 de 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Motherboard Replacement: étape 21, image 1 de 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Motherboard Replacement: étape 22, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 22, image 2 de 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Motherboard Replacement, Motherboard Cover: étape 23, image 1 de 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Motherboard Replacement: étape 24, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 24, image 2 de 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Motherboard Replacement: étape 25, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 25, image 2 de 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Motherboard Replacement: étape 26, image 1 de 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Motherboard Replacement: étape 27, image 1 de 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Motherboard Replacement: étape 28, image 1 de 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Motherboard Replacement: étape 29, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 29, image 2 de 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Motherboard Replacement: étape 30, image 1 de 3 Nintendo Wii Motherboard Replacement: étape 30, image 2 de 3 Nintendo Wii Motherboard Replacement: étape 30, image 3 de 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Motherboard Replacement: étape 31, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 31, image 2 de 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Motherboard Replacement: étape 32, image 1 de 3 Nintendo Wii Motherboard Replacement: étape 32, image 2 de 3 Nintendo Wii Motherboard Replacement: étape 32, image 3 de 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Motherboard Replacement: étape 33, image 1 de 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Motherboard Replacement: étape 34, image 1 de 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Motherboard Replacement, Heat Sink: étape 35, image 1 de 1
    • Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
  36. Nintendo Wii Motherboard Replacement: étape 36, image 1 de 1
    • Lift the heat sink off the motherboard.
    • When working near the exposed processors, be sure not to disturb the thermal pads if you don't plan to replace them. They are fragile and can tear easily. If you do plan to replace the thermal pads, thermal paste can be used.
  37. Nintendo Wii Motherboard Replacement, Motherboard: étape 37, image 1 de 1
    • Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
    • Remove the Wi-Fi board & antennas from the Wii.
  38. Nintendo Wii Motherboard Replacement: étape 38, image 1 de 1
    • Use the flat end of a spudger or your fingertips to lift up the end of the Bluetooth board nearest the center of the motherboard.
    • Carefully peel the front edge of the Bluetooth board off the EMI foam attached to the motherboard.
    • Remove the Bluetooth board.
  39. Nintendo Wii Motherboard Replacement: étape 39, image 1 de 2 Nintendo Wii Motherboard Replacement: étape 39, image 2 de 2
    • Use your fingernail to flip up the DVD drive ribbon cable retaining flap.
    • Pull the DVD drive ribbon cable out of its socket and remove it from the Wii.
  40. Nintendo Wii Motherboard Replacement: étape 40, image 1 de 1
    • Carefully pull the DVD drive power cable away from its socket on the motherboard and remove it from the Wii.
  41. Nintendo Wii Motherboard Replacement: étape 41, image 1 de 1
    • Carefully grab the motherboard by its edges and lift it off the bottom panel.
40 autres ont terminé cette réparation.
5 commentaires
Any idea if there is a common issue effecting these motherboards that causes them to fail? Perhaps I'm wondering if there is a best-practice method for determining where and/or why my Wii's MB failed (circuit tracing, component testing, soldered fuses, etc.). Upon lengthy inspection, I am unable to find any components with the usually noticeable burn marks, leaky/exploded capacitors, discolored parts or similar visual cues telling me why this MB failed.
And as a side note, I've already testing this Wii's power supply and it's 100%.
Thoughts?
Ryan R. Smith - Réponse
I just found this post about on-board fuses, but the other parts of my original question still apply.
Remplacement des fusibles de la carte de lecteur de la Nintendo Wii
If I determine it's a fuse-related issue, I'll post an update here.
Our WII unit was hit by a power surge…was not able to get it to work after that. Will motherboard replacement likely resolve most issues related to this?
Brian Walk - Réponse
Thank you for these detailed instructions! I was able to replace my original 01 board with rev. 60 and it's working beautifully! Can't thank you enough!
Dan Melton - Réponse
Thanks for this guide, the pictures are very helpful! I was able to use this to help replace the original white shell with an after-market one.
Cynthia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 22
7 derniers jours : 145
30 derniers jours : 702
Total : 89,077
