Aller au contenu principal
Nintendo Wii Outer Case Replacement
Ce dont vous avez besoin
  1. Nintendo Wii Outer Case Replacement, Faceplate: étape 1, image 1 de 2 Nintendo Wii Outer Case Replacement, Faceplate: étape 1, image 2 de 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Outer Case Replacement: étape 2, image 1 de 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Outer Case Replacement: étape 3, image 1 de 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Outer Case Replacement: étape 4, image 1 de 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Outer Case Replacement: étape 5, image 1 de 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Outer Case Replacement: étape 6, image 1 de 2 Nintendo Wii Outer Case Replacement: étape 6, image 2 de 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Outer Case Replacement, Outer Case: étape 7, image 1 de 3 Nintendo Wii Outer Case Replacement, Outer Case: étape 7, image 2 de 3 Nintendo Wii Outer Case Replacement, Outer Case: étape 7, image 3 de 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Outer Case Replacement: étape 8, image 1 de 2 Nintendo Wii Outer Case Replacement: étape 8, image 2 de 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Outer Case Replacement: étape 9, image 1 de 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Outer Case Replacement: étape 10, image 1 de 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Outer Case Replacement: étape 11, image 1 de 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Outer Case Replacement: étape 12, image 1 de 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Outer Case Replacement: étape 13, image 1 de 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Outer Case Replacement: étape 14, image 1 de 1
    • Lift the outer case straight up off the body of the Wii.
37 autres ont terminé cette réparation.
4 commentaires
Great guide. I had no problems.
wewomack - Réponse
Ugh, I went and purchased an iFixit Essential Electronics Toolkit and the Tri-wing screwdriver is too small! Y000 is what it says on the box, time to return this purchase.
iamstilllaughing - Réponse
Unfortunately this guide stops half way through and doesn’t include the other side of the case, which involves quite a few screws as the motherboard is screwed down in quite a few places, and the cpu heatsink has to come up, it’s much more complicated than this.
Lily Larceny - Réponse
yes i would love if the poster edited the guide and made it so it could be used as a "reshell" guide because i am considering purchaseing a lower condition wii and reshelling it in another color
Sqwerks -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 17
7 derniers jours : 129
30 derniers jours : 501
Total : 45,199
