Aller au contenu principal
Nintendo Wii Remote Disassembly and Corrosion Cleaning
Ce dont vous avez besoin
  1. Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 1, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 1, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 1, image 3 de 3
    • Remove the battery cover and the batteries.
    • Remove the four tri-point Y1 screws holding the remote together.
  2. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 2, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 2, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 2, image 3 de 3
    • Using an opening tool, apply pressure to the tabs located near the "A" button.
    • The tabs can break, but the remote will still work even if they do break.
    • Remove the faceplate.
  3. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 3, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 3, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 3, image 3 de 3
    • To remove the motherboard, press up on the "B" button, and then the connector at the bottom.
  4. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 4, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 4, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 4, image 3 de 3
    • Unclip the tabs to remove the plastic piece.
    • On the back, move the vibration motor out of the way to completely remove the plastic piece.
  5. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 5, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 5, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 5, image 3 de 3
    • Find any corrosion on the motherboard.
    • Corrosion on the motherboard will have a blueish color and may appear in multiple places.
    • Check the battery terminals for corrosion.
    • If batteries leaked in the remote, there will be corrosion on the terminals.
  6. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 6, image 1 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 6, image 2 de 3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 6, image 3 de 3
    • Clean the corroded areas with isopropyl alcohol and a toothbrush.
    • Q-tips can be used instead of a toothbrush.
    • Cleaning won't make look it perfect, but the remote will work again.
  7. Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 7, image 1 de 2 Nintendo Wii Remote Disassembly and Corrosion Cleaning: étape 7, image 2 de 2
    • Clean the terminals with isopropyl alcohol and a toothbrush or Q-tips.
    • It is difficult to remove this piece, so clean it as good as you can. Using more isopropyl alcohol helps here.
11 autres ont terminé cette réparation.
Stefan Kula
Membre depuis le 03/21/21
469 Réputation
1 tutoriel rédigé
2 commentaires
Would 99% Isopropyl Alcohol also be okay to use as cleaner?
Mirela - Réponse
Of course, I use this for cleaning every type of motherboard, the difference between 99% and 70% is that the solution contains less water, so the liquid evaporate in less time :)
ReDeath_ -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 47
7 derniers jours : 221
30 derniers jours : 896
Total : 19,567
