Outils
Pièces
Aucune pièce spécifiée.
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Tilt the remote, without the front cover plate, upward so the handle strap is at the bottom and the black screen is facing you.
Grip the outward edge of the screen with your fingers.
Gently, pull the screen straight outward from its housing. The screen will slide directly out.
7 autre(s) ont terminé cette réparation.
