Introduction
Use this guide to replace the analog stick in your Nintendo Wii U GamePad.
Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
Lift up and remove the battery cover.
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
Take out the left and right shoulder buttons in the upper corners.
Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
70 autre(s) ont terminé cette réparation.
34 commentaires
where can i find replacement analogs for wiiu gamepad and wiiu procontoller?
www.ebay.com
They are available at ebay.com Cost around 7,50 $ Left & Right (different - look what you need). Comes all from china or hong Kong but Quality is 1A (so far i can tell).
Bump previous question because dogs seem to enjoy their texture.
Has anyone tried this?
http://dx.com/p/replacement-3d-analog-st...
I know it says for the pro controller. But based from the images, the pins could be compatible.
