Aller au contenu principal
Nintendo Wii U Motherboard Replacement
Ce dont vous avez besoin
  1. Nintendo Wii U Motherboard Replacement, Console Outer Case: étape 1, image 1 de 1
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Nintendo Wii U Motherboard Replacement: étape 2, image 1 de 1
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. Nintendo Wii U Motherboard Replacement: étape 3, image 1 de 2 Nintendo Wii U Motherboard Replacement: étape 3, image 2 de 2
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. Nintendo Wii U Motherboard Replacement: étape 4, image 1 de 1
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. Nintendo Wii U Motherboard Replacement: étape 5, image 1 de 3 Nintendo Wii U Motherboard Replacement: étape 5, image 2 de 3 Nintendo Wii U Motherboard Replacement: étape 5, image 3 de 3
    • On the back of the console, lift up and release the main top cover.
  6. Nintendo Wii U Motherboard Replacement, Front Faceplate: étape 6, image 1 de 2 Nintendo Wii U Motherboard Replacement, Front Faceplate: étape 6, image 2 de 2
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Nintendo Wii U Motherboard Replacement: étape 7, image 1 de 1
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • The ribbon cable is connected to the system by a latch which holds in the blue tab. Flip this latch up to unlock it.
    • Lift up on the blue tab to release the ribbon cable.
  8. Nintendo Wii U Motherboard Replacement: étape 8, image 1 de 1
    • Remove the front faceplate.
  9. Nintendo Wii U Motherboard Replacement, DVD Drive: étape 9, image 1 de 1
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Nintendo Wii U Motherboard Replacement: étape 10, image 1 de 2 Nintendo Wii U Motherboard Replacement: étape 10, image 2 de 2
    • Rotate the device so that the disc drive slot is visible.
    • A ribbon cable is attached to the bottom right side of the disc drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the disc drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Nintendo Wii U Motherboard Replacement: étape 11, image 1 de 1
    • Remove the disc drive.
  12. Nintendo Wii U Motherboard Replacement, Motherboard: étape 12, image 1 de 3 Nintendo Wii U Motherboard Replacement, Motherboard: étape 12, image 2 de 3 Nintendo Wii U Motherboard Replacement, Motherboard: étape 12, image 3 de 3
    • Remove the black plastic shielding by unscrewing connecting screws with a Phillip's Head screwdriver.
    • You will have to carefully adjust the antenna cables out of the way in order to proceed comfortably.
  13. Nintendo Wii U Motherboard Replacement: étape 13, image 1 de 3 Nintendo Wii U Motherboard Replacement: étape 13, image 2 de 3 Nintendo Wii U Motherboard Replacement: étape 13, image 3 de 3
    • The metal cap does not require unscrewing and should lift up with ease.
    • Unscrew all the screws that outline the perimeter of the board using a Phillips Head (PH1) screwdriver.
    • Remove the silver shielding plate once all screws are removed. Be careful when pulling it under the affixed antenna cables.
  14. Nintendo Wii U Motherboard Replacement: étape 14, image 1 de 2 Nintendo Wii U Motherboard Replacement: étape 14, image 2 de 2
    • At this point, the motherboard should easily separate from the lower tray.
14 autres ont terminé cette réparation.
Emily Vasquez
Membre depuis le 02/24/16
884 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Leahy Spring 2016 Membre de l'équipe USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
3 membres
12 tutoriels rédigés
2 commentaires
Does anyone knows where I can buy a Wii U Motherboard? mine has a dead CPU/GPU :(((((
AppleTopic - Réponse
This really feels like a "draw the rest of the f***ing owl" kind of guide. "Remove the black plastic shielding by unscrewing connecting screws"? Which ones???
Lucas Newton - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 69
30 derniers jours : 328
Total : 18,431
