Aller au contenu principal
Nintendo Wii Wi-Fi Antennas Replacement
Ce dont vous avez besoin
  1. Nintendo Wii Wi-Fi Antennas Replacement, Faceplate: étape 1, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement, Faceplate: étape 1, image 2 de 2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Wi-Fi Antennas Replacement: étape 2, image 1 de 1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Wi-Fi Antennas Replacement: étape 3, image 1 de 1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Wi-Fi Antennas Replacement: étape 4, image 1 de 1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Wi-Fi Antennas Replacement: étape 5, image 1 de 1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Wi-Fi Antennas Replacement: étape 6, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 6, image 2 de 2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Wi-Fi Antennas Replacement, Outer Case: étape 7, image 1 de 3 Nintendo Wii Wi-Fi Antennas Replacement, Outer Case: étape 7, image 2 de 3 Nintendo Wii Wi-Fi Antennas Replacement, Outer Case: étape 7, image 3 de 3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Wi-Fi Antennas Replacement: étape 8, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 8, image 2 de 2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Wi-Fi Antennas Replacement: étape 9, image 1 de 1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Wi-Fi Antennas Replacement: étape 10, image 1 de 1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Wi-Fi Antennas Replacement: étape 11, image 1 de 1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Wi-Fi Antennas Replacement: étape 12, image 1 de 1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Wi-Fi Antennas Replacement: étape 13, image 1 de 1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Wi-Fi Antennas Replacement: étape 14, image 1 de 1
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Wi-Fi Antennas Replacement, DVD Drive: étape 15, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement, DVD Drive: étape 15, image 2 de 2
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Wi-Fi Antennas Replacement: étape 16, image 1 de 1
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
  17. Nintendo Wii Wi-Fi Antennas Replacement: étape 17, image 1 de 1
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Wi-Fi Antennas Replacement: étape 18, image 1 de 1
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Wi-Fi Antennas Replacement: étape 19, image 1 de 1
    • Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Wi-Fi Antennas Replacement: étape 20, image 1 de 1
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Wi-Fi Antennas Replacement: étape 21, image 1 de 1
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Wi-Fi Antennas Replacement: étape 22, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 22, image 2 de 2
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Wi-Fi Antennas Replacement, Motherboard Cover: étape 23, image 1 de 1
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Wi-Fi Antennas Replacement: étape 24, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 24, image 2 de 2
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Wi-Fi Antennas Replacement: étape 25, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 25, image 2 de 2
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Wi-Fi Antennas Replacement: étape 26, image 1 de 1
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Wi-Fi Antennas Replacement: étape 27, image 1 de 1
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Wi-Fi Antennas Replacement: étape 28, image 1 de 1
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Wi-Fi Antennas Replacement: étape 29, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 29, image 2 de 2
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Wi-Fi Antennas Replacement: étape 30, image 1 de 3 Nintendo Wii Wi-Fi Antennas Replacement: étape 30, image 2 de 3 Nintendo Wii Wi-Fi Antennas Replacement: étape 30, image 3 de 3
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Wi-Fi Antennas Replacement: étape 31, image 1 de 2 Nintendo Wii Wi-Fi Antennas Replacement: étape 31, image 2 de 2
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Wi-Fi Antennas Replacement: étape 32, image 1 de 3 Nintendo Wii Wi-Fi Antennas Replacement: étape 32, image 2 de 3 Nintendo Wii Wi-Fi Antennas Replacement: étape 32, image 3 de 3
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Wi-Fi Antennas Replacement: étape 33, image 1 de 1
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Wi-Fi Antennas Replacement: étape 34, image 1 de 1
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Wi-Fi Antennas Replacement, Wi-Fi Antennas: étape 35, image 1 de 1
    • Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
  36. Nintendo Wii Wi-Fi Antennas Replacement: étape 36, image 1 de 1
    • Use the flat end of a spudger to pry both antenna connectors off their sockets on the Wi-Fi board.
5 autres ont terminé cette réparation.
Un commentaire
After I pry the antenna's off then what
Brendan keller - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 64
Total : 12,890
