Aller au contenu principal
Nissan Kicks Repair Cabin Air Filter Replacement
Ce dont vous avez besoin
  1. Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 2 Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 2 de 2
    • Remove the floor mat or any items in the passenger footwell of your car.
    • Use a trim tool on the inner panel beneath the glove box to release the clips and pry it out.
    • Place your hand on the far back of the panel to remove it.
    • It may require a hard tug to remove the panel.
  2. Nissan Kicks Repair Cabin Air Filter Replacement: étape 2, image 1 de 2 Nissan Kicks Repair Cabin Air Filter Replacement: étape 2, image 2 de 2
    • Press the tab on the bottom of the filter lid to unlock it.
    • Open the lid and pull out the old filter.
    • You may want to wear gloves or a mask in case there is a lot of debris in the filter. (Especially if it's been a long time since you last changed the filter.)
  3. Nissan Kicks Repair Cabin Air Filter Replacement: étape 3, image 1 de 1
    • Insert the new filter with the arrows oriented correctly.
    • Start at the top edge of the filter, then push in the bottom, followed by the rest of the filter.
    • The direction of the arrows for the newly installed filter is dependent on what filter you purchase.
    • The arrows indicate the direction of air flow.
  4. Nissan Kicks Repair Cabin Air Filter Replacement: étape 4, image 1 de 1
    • Close the lid and push the bottom in until you hear it click.
  5. Nissan Kicks Repair Cabin Air Filter Replacement: étape 5, image 1 de 1
    • Replace the panel back and press firmly in the middle and around the edges to ensure it is locked in.
    • Give the panel a light tug afterward to make sure it is secure.
Ligne d'arrivée
William Do
Membre depuis le 03/02/24
171 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 52-1, Watkins Spring 2024 Membre de l'équipe Austin Community College, Team 52-1, Watkins Spring 2024
AUSTINCC-WATKINS-S24S52G1
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 53
Total : 117
