Aller au contenu principal
Nixon Mission Android Wear Front Screen Replacement
Ce dont vous avez besoin
  1. Nixon Mission Android Wear Front Screen  Replacement, Front Screen: étape 1, image 1 de 1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Front Screen  Replacement: étape 2, image 1 de 1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Front Screen  Replacement: étape 3, image 1 de 1
    • Unclip 5 latches from motherboard using a spudger.
  4. Nixon Mission Android Wear Front Screen  Replacement: étape 4, image 1 de 1
    • Remove 2 3.0mm Phillips screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Front Screen  Replacement: étape 5, image 1 de 1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Front Screen  Replacement: étape 6, image 1 de 1
    • Remove 4 7.0mm hex-screws from front of watch using H1.5 Hex head.
  7. Nixon Mission Android Wear Front Screen  Replacement: étape 7, image 1 de 1
    • Remove outer screen frame from front of watch.
  8. Nixon Mission Android Wear Front Screen  Replacement: étape 8, image 1 de 1
    • Remove 4 4.5mm Phillips gold screws from back of watch using PH00 Phillips head.
  9. Nixon Mission Android Wear Front Screen  Replacement: étape 9, image 1 de 1
    • Remove outer protective screen.
    • Replace outer protective screen with the new part.
Venkata
Membre depuis le 11/07/17
113 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G2, Harley Fall 2017 Membre de l'équipe IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
3 membres
3 tutoriels rédigés
2 commentaires
But can you even buy replacement screen
Josh Leaney - Réponse
Where can you buy a replacement screen?
Ethan Whitton - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 775
