Aller au contenu principal
Nobis NB07 Microphone Replacement
Ce dont vous avez besoin
  1. Nobis NB07 Microphone Replacement, Opening the case: étape 1, image 1 de 1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Microphone Replacement: étape 2, image 1 de 3 Nobis NB07 Microphone Replacement: étape 2, image 2 de 3 Nobis NB07 Microphone Replacement: étape 2, image 3 de 3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Microphone Replacement, Replacing the battery: étape 3, image 1 de 3 Nobis NB07 Microphone Replacement, Replacing the battery: étape 3, image 2 de 3 Nobis NB07 Microphone Replacement, Replacing the battery: étape 3, image 3 de 3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Microphone Replacement: étape 4, image 1 de 3 Nobis NB07 Microphone Replacement: étape 4, image 2 de 3 Nobis NB07 Microphone Replacement: étape 4, image 3 de 3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Microphone Replacement: étape 5, image 1 de 1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Microphone Replacement: étape 6, image 1 de 2 Nobis NB07 Microphone Replacement: étape 6, image 2 de 2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Microphone Replacement, Removing the cameras: étape 7, image 1 de 3 Nobis NB07 Microphone Replacement, Removing the cameras: étape 7, image 2 de 3 Nobis NB07 Microphone Replacement, Removing the cameras: étape 7, image 3 de 3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Microphone Replacement: étape 8, image 1 de 2 Nobis NB07 Microphone Replacement: étape 8, image 2 de 2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Microphone Replacement: étape 9, image 1 de 3 Nobis NB07 Microphone Replacement: étape 9, image 2 de 3 Nobis NB07 Microphone Replacement: étape 9, image 3 de 3
    Outil utilisé dans cette étape :
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
  10. Nobis NB07 Microphone Replacement, Removing the microphone: étape 10, image 1 de 1
    • Locate the microphone's cables in front of the cameras' ZIF connector.
  11. Nobis NB07 Microphone Replacement: étape 11, image 1 de 1
  12. Nobis NB07 Microphone Replacement: étape 12, image 1 de 2 Nobis NB07 Microphone Replacement: étape 12, image 2 de 2
    • Use the pointy end of the tweezers to retrieve the microphone from its socket.
    • You can now remove the microphone.
Daniel Gomero
Membre depuis le 01/21/15
966 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 5-5, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 5-5, Brown Winter 2015
USFT-BROWN-W15S5G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 160
