Aller au contenu principal
Nokero N400 LED Panel Replacement
Ce dont vous avez besoin
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: étape 1, image 1 de 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: étape 1, image 2 de 3 Nokero N400 LED Panel Replacement, Remove Battery Cover: étape 1, image 3 de 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: étape 2, image 1 de 2 Nokero N400 LED Panel Replacement, Unscrew Back Cover: étape 2, image 2 de 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: étape 3, image 1 de 2 Nokero N400 LED Panel Replacement, Pry Open Back Cover: étape 3, image 2 de 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: étape 4, image 1 de 2 Nokero N400 LED Panel Replacement, Removing the LED Panel: étape 4, image 2 de 2
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: étape 5, image 1 de 1
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
Kyle Burwell
Membre depuis le 01/20/15
173 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 153
