Aller au contenu principal
Nokero N400 Switch Replacement
Ce dont vous avez besoin
  1. Nokero N400 Switch Replacement, Remove Battery Cover: étape 1, image 1 de 3 Nokero N400 Switch Replacement, Remove Battery Cover: étape 1, image 2 de 3 Nokero N400 Switch Replacement, Remove Battery Cover: étape 1, image 3 de 3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Switch Replacement, Unscrew Back Cover: étape 2, image 1 de 2 Nokero N400 Switch Replacement, Unscrew Back Cover: étape 2, image 2 de 2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Switch Replacement, Pry Open Back Cover: étape 3, image 1 de 2 Nokero N400 Switch Replacement, Pry Open Back Cover: étape 3, image 2 de 2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Switch Replacement, Remove Switch From Housing: étape 4, image 1 de 1
    • Using a spudger carefully pry switch from housing.
  5. Nokero N400 Switch Replacement, Cut Old Switch Free: étape 5, image 1 de 1
    • Use wire cutters to cut the two black wires attached to the old switch.
    • You must use a splicer or a soldering gun to reattach the wires of the new switch.
    • If you splice the new switch wires together in the opposite order of the old switch wires, the new switch will still work.
Benjamin franklin
Membre depuis le 01/20/15
101 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 19-2, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 19-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 130
