Aller au contenu principal
Nokero SunRay Pro Power Panel Front and Back Case Replacement
Ce dont vous avez besoin
  1. Nokero SunRay Pro Power Panel Front and Back Case Replacement, Front and Back Case: étape 1, image 1 de 1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 2, image 1 de 3 Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 2, image 2 de 3 Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 2, image 3 de 3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 3, image 1 de 2 Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 3, image 2 de 2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 4, image 1 de 2 Nokero SunRay Pro Power Panel Front and Back Case Replacement: étape 4, image 2 de 2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
Jeremy
Membre depuis le 01/21/15
157 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 9-3, Blackwell Winter 2015 Membre de l'équipe USF Tampa, Team 9-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 7
Total : 224
