Aller au contenu principal
Nokia 2115i Faceplate Replacement
Ce dont vous avez besoin
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: étape 1, image 1 de 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: étape 1, image 2 de 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: étape 1, image 3 de 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: étape 2, image 1 de 2 Nokia 2115i Faceplate Replacement: étape 2, image 2 de 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: étape 3, image 1 de 3 Nokia 2115i Faceplate Replacement, Faceplate: étape 3, image 2 de 3 Nokia 2115i Faceplate Replacement, Faceplate: étape 3, image 3 de 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
Shane
Membre depuis le 09/30/10
80 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-38, Forte Fall 2010 Membre de l'équipe Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 1,612
