Introduction
If the phone will not take a charge and it is not a battery related issue, change the charging port.
Ce dont vous avez besoin
Be sure cell phone is off before you begin to disassemble the phone.
Press the button on the bottom of the back of the cell phone.
Slide rear panel down and remove it.
Insert the plastic opening tool under the faceplate.
Separate the faceplate from main body by twisting the prying tool with some force.
The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
Locate and remove the six screws on the front of the phone using a T6 Torx.
All 6 screws are 6.9mm long.
With the logic board and LCD unit removed, gently pry out the charging port.
