Aller au contenu principal
Nokia 2128i Motherboard Assembly Replacement
Ce dont vous avez besoin
  1. Nokia 2128i Motherboard Assembly Replacement, Battery: étape 1, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement, Battery: étape 1, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement, Battery: étape 1, image 3 de 3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Motherboard Assembly Replacement: étape 2, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement: étape 2, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement: étape 2, image 3 de 3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Motherboard Assembly Replacement, Faceplate: étape 3, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement, Faceplate: étape 3, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement, Faceplate: étape 3, image 3 de 3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Motherboard Assembly Replacement, Keypad: étape 4, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement, Keypad: étape 4, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement, Keypad: étape 4, image 3 de 3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: étape 5, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: étape 5, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement, Motherboard Assembly: étape 5, image 3 de 3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Motherboard Assembly Replacement: étape 6, image 1 de 3 Nokia 2128i Motherboard Assembly Replacement: étape 6, image 2 de 3 Nokia 2128i Motherboard Assembly Replacement: étape 6, image 3 de 3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
Chad
Membre depuis le 10/29/10
19 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 20-8, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 20-8, Maness Fall 2010
CPSU-MANESS-F10S20G8
4 membres
24 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,473
