Aller au contenu principal
Nokia 3.1 Battery Replacement
Ce dont vous avez besoin
  1. Nokia 3.1 Battery Replacement, Battery: étape 1, image 1 de 1
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: étape 2, image 1 de 3 Nokia 3.1 Battery Replacement, Open the back cover: étape 2, image 2 de 3 Nokia 3.1 Battery Replacement, Open the back cover: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: étape 3, image 1 de 2 Nokia 3.1 Battery Replacement, Remove logic board cover: étape 3, image 2 de 2
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: étape 4, image 1 de 2 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: étape 4, image 2 de 2
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
9 autres ont terminé cette réparation.
Baschtl
Membre depuis le 12/02/12
1 576 Réputation
5 tutoriels rédigés
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 23
30 derniers jours : 108
Total : 6,926
