Introduction
To change or clean the logic board the phone must be dissembled. The tools required will be a T-6 screw driver.
Ce dont vous avez besoin
Flip the Nokia 3300B over with the back-side facing towards you.
Gently press the button on the back of the battery cover to release the cover and slide up.
Outil utilisé dans cette étape :Tweezers$4.99
Gently push the blue tabs on the top of the phone out of their slots.
With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
3 autres ont terminé cette réparation.
