Aller au contenu principal
Introduction
This guide shows a step by step guide to fully access the keyboard, to clean it if it is sticking or completely replace the keypad if it is broken.
  1. Nokia 3310 3G Keyboard Replacement, Battery: étape 1, image 1 de 2 Nokia 3310 3G Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: étape 2, image 1 de 2 Nokia 3310 3G Keyboard Replacement: étape 2, image 2 de 2
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: étape 3, image 1 de 3 Nokia 3310 3G Keyboard Replacement, Frame: étape 3, image 2 de 3 Nokia 3310 3G Keyboard Replacement, Frame: étape 3, image 3 de 3
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: étape 4, image 1 de 3 Nokia 3310 3G Keyboard Replacement, Motherboard: étape 4, image 2 de 3 Nokia 3310 3G Keyboard Replacement, Motherboard: étape 4, image 3 de 3
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: étape 5, image 1 de 3 Nokia 3310 3G Keyboard Replacement, Keyboard: étape 5, image 2 de 3 Nokia 3310 3G Keyboard Replacement, Keyboard: étape 5, image 3 de 3
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
  6. Nokia 3310 3G Keyboard Replacement: étape 6, image 1 de 1
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
4 autres ont terminé cette réparation.
Aaron LeBlanc
Membre depuis le 24/10/2018
699 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G3, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G3, Peak Fall 2018
UMASSD-PEAK-F18S3G3
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 34
Total : 1,428
