Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Changing the Battery is easy -- no tools required.
  1. Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time. To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Lift the battery out of the phone. Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
2 autre(s) ont terminé cette réparation.
Travis Malmgren
Membre depuis le 26/01/2010
69 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 8-39, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 membres
12 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 2,186
