Aller au contenu principal
Nokia 3360 Cover Plate Replacement
  1. Nokia 3360 Cover Plate Replacement, Battery: étape 1, image 1 de 1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Cover Plate Replacement: étape 2, image 1 de 2 Nokia 3360 Cover Plate Replacement: étape 2, image 2 de 2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Cover Plate Replacement: étape 3, image 1 de 2 Nokia 3360 Cover Plate Replacement: étape 3, image 2 de 2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Cover Plate Replacement, Cover Plate: étape 4, image 1 de 2 Nokia 3360 Cover Plate Replacement, Cover Plate: étape 4, image 2 de 2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
2 autres ont terminé cette réparation.
Kirk Gonzalez
Membre depuis le 01/22/10
223 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 8-39, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 8-39, Regan Winter 2010
CPSU-REGAN-W10S8G39
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 20
Total : 2,682
