Aller au contenu principal
Nokia 5130 XpressMusic Logic Board / Casing Replacement
Ce dont vous avez besoin
  1. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Sliding off the rear panel: étape 1, image 1 de 1
    • Slide the rear panel in the indicated direction to unlock it.
  2. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: étape 2, image 1 de 2 Nokia 5130 XpressMusic Logic Board / Casing Replacement, Lifting up the rear panel: étape 2, image 2 de 2
    • After unlocking it, the rear panel can now be lifted up.
  3. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Rear screws: étape 3, image 1 de 1
    • Remove the two T6 screws near the camera
  4. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Unclip the bezel: étape 4, image 1 de 1
    • Unclip the several clips holding the front bezel in place
    • Be sure not to break off or damage the clips, otherwise the front bezel might no longer stay in place!
  5. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Keypad: étape 5, image 1 de 1
    • Push in the pins holding in the keypad
  6. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the keypad: étape 6, image 1 de 1
    • The keypad can now be removed.
  7. Nokia 5130 XpressMusic Logic Board / Casing Replacement, Remove the remaining parts: étape 7, image 1 de 1
    • Lift up the logic board / display and remove it from the case.
iSzymon
Membre depuis le 10/13/20
630 Réputation
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 448
