Aller au contenu principal
Nokia 515 Front cover and keypad replacement
Ce dont vous avez besoin
  1. Nokia 515 Front cover and keypad replacement, Front cover and keypad: étape 1, image 1 de 1
    • Remove the back cover with your fingers or with the eject tool which is included by Nokia.
    • Don't forget to turn off your device!
  2. Nokia 515 Front cover and keypad replacement: étape 2, image 1 de 1
    • Remove the battery, the microSD card and the SIM card.
  3. Nokia 515 Front cover and keypad replacement: étape 3, image 1 de 1
    • Remove the 2 screws with the T4 screwdriver.
    • Please store the screws on a safe place! I already lost a screw!
  4. Nokia 515 Front cover and keypad replacement: étape 4, image 1 de 2 Nokia 515 Front cover and keypad replacement: étape 4, image 2 de 2
    • Take the metal spudger and pry it firmly under the plastic hinges.
    • Although you want to replace the cover, be very careful by doing it! You could harm yourself with the metal spudger.
    • You could also use your fingers instead of the spudger to do it!
  5. Nokia 515 Front cover and keypad replacement, Remove the keypad: étape 5, image 1 de 3 Nokia 515 Front cover and keypad replacement, Remove the keypad: étape 5, image 2 de 3 Nokia 515 Front cover and keypad replacement, Remove the keypad: étape 5, image 3 de 3
    • To remove the keypad, you should use the spudger to push the top clamps down a little bit while pressing your fingers against the inside of the keypad.
    • The keypad should be loose at the top.
    • To remove the bottom, just use a little bit of force to pull it off the front panel.
    • Just use a little bit of force.
  6. Nokia 515 Front cover and keypad replacement: étape 6, image 1 de 1
    • To assemble the new keypad, start at the upper half of the keyboard.
  7. Nokia 515 Front cover and keypad replacement: étape 7, image 1 de 3 Nokia 515 Front cover and keypad replacement: étape 7, image 2 de 3 Nokia 515 Front cover and keypad replacement: étape 7, image 3 de 3
    • To reassemble the front, just click it in place (you hear a clicking noise).
    • Now screw the T4 screws back into the holes.
    • Now you put the microSD card, the SIM card and the battery back into your device.
    • Now you can turn on your device.
You did it!
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
de en
100%
Leon nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Leon
Membre depuis le 03/28/19
389 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 19
Total : 1,054
