Aller au contenu principal
Nokia 5165 Front Cover Replacement
Ce dont vous avez besoin
  1. Nokia 5165 Front Cover Replacement, Removing the Cover: étape 1, image 1 de 1
    • Find the tab at the top of the phone and press down with your fingernail or the flat end of a spudger
  2. Nokia 5165 Front Cover Replacement: étape 2, image 1 de 3 Nokia 5165 Front Cover Replacement: étape 2, image 2 de 3 Nokia 5165 Front Cover Replacement: étape 2, image 3 de 3
    • The top of the cover should pop out a little bit, pull the top of the cover out and the cover should come off
  3. Nokia 5165 Front Cover Replacement, Removing The Buttons: étape 3, image 1 de 3 Nokia 5165 Front Cover Replacement, Removing The Buttons: étape 3, image 2 de 3 Nokia 5165 Front Cover Replacement, Removing The Buttons: étape 3, image 3 de 3
    • Pull off the number pad and store it some where safe, you'll need it for the new cover
    • Remove the power button with the flat end of a spudger by getting the spudger under the button and pulling it up by the red tabs
  4. Nokia 5165 Front Cover Replacement, Prepping The New Cover: étape 4, image 1 de 3 Nokia 5165 Front Cover Replacement, Prepping The New Cover: étape 4, image 2 de 3 Nokia 5165 Front Cover Replacement, Prepping The New Cover: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Put the number pad into the new cover and push it down
    • For the power button, I recommend using blunt nose tweezers to put the button in with the slope on the top of the button going down towards the speaker hole, then using a spudger to push it in
    • Using pointed tweezers can put holes in the power button and possibly break the button, only use blunt nose tweezers
  5. Nokia 5165 Front Cover Replacement, Attacing The New Cover: étape 5, image 1 de 3 Nokia 5165 Front Cover Replacement, Attacing The New Cover: étape 5, image 2 de 3 Nokia 5165 Front Cover Replacement, Attacing The New Cover: étape 5, image 3 de 3
    • Make sure the two tabs at the bottom of the cover go into the phone first at an angle, the push the top of the cover in until it clicks and then you are done!
Now you have a new cover!
Ethan Pikscher
Membre depuis le 12/19/18
351 Réputation
3 tutoriels rédigés
Équipe
Kid fixers Membre de l'équipe Kid fixers
Community
184 membres
256 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 106
