Ce dont vous avez besoin
Slide the black battery cover down and off the phone with your thumb to remove it.
On some models, the front case is screwed down from the back. Follow steps 5 and 6 first to remove the camera cover and two T6 screws, BEFORE removing the faceplate.
Find a small latch under the music keys and in the middle of each side of the faceplate.
Gently lift the edges of the front faceplate off the phone using a spudger.
Flip the phone over to the back side.
Unsnap the back camera cover from the phone.
Lift to remove the back camera cover from the phone after it has been unsnapped.
Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
6 autres ont terminé cette réparation.
1 commentaire de tutoriel
Thank you much! As efficient & thorough as it gets!
