Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nokia 6 Midframe Replacement
Ce dont vous avez besoin
  1. Nokia 6 Midframe Replacement, Display Assembly: étape 1, image 1 de 3 Nokia 6 Midframe Replacement, Display Assembly: étape 1, image 2 de 3 Nokia 6 Midframe Replacement, Display Assembly: étape 1, image 3 de 3
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
    Demander à FixBot
  2. Nokia 6 Midframe Replacement: étape 2, image 1 de 1
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
    Demander à FixBot
  3. Nokia 6 Midframe Replacement: étape 3, image 1 de 1
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
    Demander à FixBot
  4. Nokia 6 Midframe Replacement: étape 4, image 1 de 1
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
    Demander à FixBot
  5. Nokia 6 Midframe Replacement: étape 5, image 1 de 1
    • Lift the screen off of the phone.
    Demander à FixBot
  6. Nokia 6 Midframe Replacement: étape 6, image 1 de 2 Nokia 6 Midframe Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
    Demander à FixBot
  7. Nokia 6 Midframe Replacement: étape 7, image 1 de 1
    • Remove the metal bracket with a tweezer.
    Demander à FixBot
  8. Nokia 6 Midframe Replacement: étape 8, image 1 de 1
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
    Demander à FixBot
  9. Nokia 6 Midframe Replacement, Home Button Assembly: étape 9, image 1 de 1
    • Disconnect the battery connector with a spudger.
    Demander à FixBot
  10. Nokia 6 Midframe Replacement: étape 10, image 1 de 2 Nokia 6 Midframe Replacement: étape 10, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
    Demander à FixBot
  11. Nokia 6 Midframe Replacement: étape 11, image 1 de 2 Nokia 6 Midframe Replacement: étape 11, image 2 de 2
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
    Demander à FixBot
  12. Nokia 6 Midframe Replacement, Midframe: étape 12, image 1 de 1
    • Remove 18 screws.
    • There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
    • One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
    • The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
    Demander à FixBot
  13. Nokia 6 Midframe Replacement: étape 13, image 1 de 2 Nokia 6 Midframe Replacement: étape 13, image 2 de 2
    • Decouple the midframe with the spudger and remove the midframe from the device.
    Demander à FixBot
Chrissy Robins
Membre depuis le 04/15/19
1 585 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team S9-G15, Maness Spring 2019 Membre de l'équipe Cal Poly, Team S9-G15, Maness Spring 2019
CPSU-MANESS-S19S9G15
4 membres
14 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 55
Total : 892
