Aller au contenu principal
Nokia 6086 Battery Replacement
Ce dont vous avez besoin
  1. Nokia 6086 Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: étape 2, image 1 de 3 Nokia 6086 Battery Replacement: étape 2, image 2 de 3 Nokia 6086 Battery Replacement: étape 2, image 3 de 3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: étape 3, image 1 de 3 Nokia 6086 Battery Replacement: étape 3, image 2 de 3 Nokia 6086 Battery Replacement: étape 3, image 3 de 3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
Andrea
Membre depuis le 04/15/10
70 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 26-30, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 26-30, Regan Spring 2010
CPSU-REGAN-S10S26G30
4 membres
17 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 15
Total : 3,846
