Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The back cover and the battery have to be removed before the SimCard can be reached. No tools are required.
  1. Turn the phone so it is face down (keypad side is down).
    • Turn the phone so it is face down (keypad side is down).
  2. Press and hold the button located at the bottom of the phone. Slide the back of the phone downwards and away from the main body. Remove the backing and place it to the side.
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Locate indentation from which battery can be removed. Place finger in indentation and lift battery up from phone's body. Remove battery from phone's body.
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
  5. Push the SimCard towards the bottom of the phone.
    • Push the SimCard towards the bottom of the phone.
  6. Slide finger underneath top of SimCard. Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
    • Slide finger underneath top of SimCard.
    • Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
  7. Pull up on the SimCard and remove it from the back of the phone. Place the SimCard to the side.
    • Pull up on the SimCard and remove it from the back of the phone.
    • Place the SimCard to the side.
To insert a new SimCard, simply push the card in as shown in step 6, and snap it in place.
Reid Polstra
Membre depuis le 22/10/2012
1 Réputation
7 tutoriels rédigés
Équipe
Clemson, Team 15-5, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 646
