Introduction
It’s the Nokia 8110 4G also known as the banana phone! Not only does this phone have an extremely cool sliding keypad cover, but you also don’t need to do anything special to get it open. We love an easy teardown and that’s what we got! Watch as we disassemble the Nokia 8110 4G.
Ce dont vous avez besoin
Vidéo d'introduction
- For the most part disassembly is extremely simple with only plastic clips, and standard Torx screws holding the phone together.
- The battery is easy to access and replace
- Several main components such as headphone jack, SD card slot, Micro USB port and vibrator are soldered to the motherboard.
- Getting to the display requires removing the front glass which is tricky to remove without damaging it.
Dernières pensées
Indice de réparabilité
8
Indice de réparabilité de 8 sur 10
(10 étant le plus facile à réparer)
2 commentaires
这种玻璃很难移除而不会损坏它。
这块玻璃屏在被移除时很容易遭到损坏
Hong DING - Réponse
Very good teardown clip except did not show separation between tactile matte keymat and upper case.
Abbas Abdul Wahab - Réponse
