Aller au contenu principal
Nokia 8290 Adhesive White Film Replacement
Ce dont vous avez besoin
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: étape 1, image 1 de 3 Nokia 8290 Adhesive White Film Replacement, Front Cover: étape 1, image 2 de 3 Nokia 8290 Adhesive White Film Replacement, Front Cover: étape 1, image 3 de 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: étape 2, image 1 de 3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: étape 2, image 2 de 3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: étape 2, image 3 de 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: étape 3, image 1 de 3 Nokia 8290 Adhesive White Film Replacement: étape 3, image 2 de 3 Nokia 8290 Adhesive White Film Replacement: étape 3, image 3 de 3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: étape 4, image 1 de 3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: étape 4, image 2 de 3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: étape 4, image 3 de 3
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: étape 5, image 1 de 3 Nokia 8290 Adhesive White Film Replacement: étape 5, image 2 de 3 Nokia 8290 Adhesive White Film Replacement: étape 5, image 3 de 3
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
Austin Culberson
Membre depuis le 10/22/12
87 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 15-3, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 membres
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 333
