Aller au contenu principal
Introduction
Installing a new vibration component is necessary when the vibrate mode on your phone is no longer functioning properly. Installation requires no prior knowledge of mobile phone vibrators.
Pièces
Aucune pièce spécifiée.
  1. Locate the small button on the top of the phone. Depress the button. With your other hand, pull the front cover away from the phone.
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Remove all six 5.3 mm long T6 screws. Remove the circuit board/faceplate sub-assembly from the back of the phone. Take care to place screws in a safe location.
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. After removing the circuit board/faceplate sub-assembly, locate the vibrator mechanism. Remove the vibrator mechanism with tweezers by simply pulling it up and away from the phone. Remove the vibrator mechanism with tweezers by simply pulling it up and away from the phone.
    • After removing the circuit board/faceplate sub-assembly, locate the vibrator mechanism.
    • Remove the vibrator mechanism with tweezers by simply pulling it up and away from the phone.
Parker Niebauer
Membre depuis le 22/10/2012
1 Réputation
6 tutoriels rédigés
Équipe
Clemson, Team 15-3, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 membres
21 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 451
