Aller au contenu principal
Nokia Asha 201 Audio Jack Replacement
Ce dont vous avez besoin
  1. Nokia Asha 201 Audio Jack Replacement, Audio Jack: étape 1, image 1 de 1
    • Remove the white case by popping apart the front and back with your finger.
  2. Nokia Asha 201 Audio Jack Replacement: étape 2, image 1 de 1
    • Remove the battery by taking it out with your fingers.
  3. Nokia Asha 201 Audio Jack Replacement: étape 3, image 1 de 1
    • Remove the two 5.5mm screws by using the T6 screwdriver.
  4. Nokia Asha 201 Audio Jack Replacement: étape 4, image 1 de 1
    • Use the blue plastic opening tool to remove the front of the white case.
  5. Nokia Asha 201 Audio Jack Replacement: étape 5, image 1 de 1
    • Remove the keyboard using your fingers and set aside.
  6. Nokia Asha 201 Audio Jack Replacement: étape 6, image 1 de 1
    • Unscrew the two 5.5mm screws near the bottom of the device on either side using the T6 screwdriver.
  7. Nokia Asha 201 Audio Jack Replacement: étape 7, image 1 de 1
    • Separate the black plastic internal case from the screen by prying with the blue plastic opening tool.
  8. Nokia Asha 201 Audio Jack Replacement: étape 8, image 1 de 1
    • The black plastic cover should now be separated from the motherboard. Replace the audio jack by removing it with your fingers.
Betsy Walker
Membre depuis le 10/10/19
157 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S1-G3, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 195
